It is currently Fri 04. Apr 2025 5:48:04
 Post subject: Spirit Wave Trainer Mode
PostPosted: Sat 11. Jan 2025 14:35:51
Hello Tomas,
I wanted to ask how far you have with the trainer mode on the Spirit Wave. I also give flight lessons and would like to train with my students on the wave.
LG Alex
PostPosted: Fri 17. Jan 2025 11:55:28
Trainer mode for Wave is similar to other transmitters but when pairing with other Wave radio whole model settings can be downloaded wirelessly to radio of student.
You can allow which Channels are allowed to control by trainer as well.
We plan to add few improvements there in very near future and allow more functions within 3 weeks. Then it should be perfectly mature.
PostPosted: Fri 17. Jan 2025 15:04:02
Thank you for the feedback.
Unfortunately the problem is that it doesn't work at the moment. When the transmitters connect, I have two wave transmitters, Either twitch the servo or jerky movements. I also didn't see where I could assign the switch for operation. OK then I hope it works after the 3-week update, otherwise the Wave is really great.
LG Alex
PostPosted: Sun 16. Feb 2025 14:04:37
Hello Tomas,
Is there any news about the trainer mode, possibly in the next update. The weather is getting better and better and I rely on it to work. I wouldn't like to switch to another system.
LG Alex
PostPosted: Sun 16. Feb 2025 19:43:46
New Trainer function is ready and will be released within this week together with many new improvements.
PostPosted: Sun 16. Feb 2025 23:09:44
Hello Tomas,
Thank you very much for the quick reply, I'm really looking forward to it.
LG Alex
PostPosted: Sat 22. Feb 2025 14:01:20
We are doing final testing before release. Update will contain a lot of big news.
PostPosted: Sun 23. Feb 2025 14:05:23
Thanks for the info.
I noticed one little thing: the Delta function on aircraft is not yet working correctly. Instead of mixing the height and transverse 2 outputs, 4 outputs 2 transverse and 2 side are created.
I wish you a nice weekend.
PostPosted: Thu 27. Feb 2025 10:07:03
Hello Tomas
Thanks for the trainer update, the function itself is great and works perfectly.
However, I found that as soon as the two transmitters are connected, the servos don't run cleanly. They jerk.
If I only connect one transmitter directly, they run normally clean. Could you please check this again.
The installed servos are TS Theta Razor C1, 760 US, 200 HZ, HS Theta Razor T1, 760 US, 560 HZ
Danke im voraus LG Alex
PostPosted: Thu 27. Feb 2025 10:46:44
please make sure that receiver has 1.10.6 firmware installed. New trainer mode require the recent receiver firmware to work correcty.
Today we released udated version to make sure you can't use the old receiver firmware version in no case and trainer is automatically turned off.
Users browsing this forum: Google [Bot] and 9 guests
