It is currently Wed 05. Feb 2025 9:55:57
[ 3 posts ] |
raceboy1
Posted: Sun 29. Dec 2024 16:00:41 |
I currently have four of my Heli's using Spirit GT But I ran into a problem in setting up one of my Nitro's that I use a switch to activate the Remote Glow from my Spektrum Transmitter I'm using SRLX
I can't find a way to use one of the Aux Channels on the Spirt Gt FLB , for activating by a switch I know that in the function list there's an Output to Aux 2. I don't use Banks, so is there a way to re assign the Bank Channel
The other way that I've found is using Channel 5 on my AR6610t receiver that I'm using. Which goes to INH when I setup my Gyro. But not sure if re assigning channel 5 would effect the gyro or not.
Posted: Sun 29. Dec 2024 20:19:42 |
Joined: Wed 21. Dec 2016 15:13:38 Posts: 584 Location: Germany
Hello, if you want to use an Output to Ch 0 ord AUX2 you must activite throttel-channel in the Spirit to Channel 1 - I am not shure at the moment which channel you can activate that's what you have to test it, I believe it was ch0 but not shure - one channel works at 60hz at standard, like the throttlechannel 1 - If you don't actvate the throttle-channel the outputs will not work -
Posted: Mon 06. Jan 2025 8:40:27 |
in the General - Channels window you can set F: Output to AUX2 or CH0 function. This will output signal from selected channel to the Spirit port. It can be used for controlloing Glow Plug.
I recommend to use AUX2 port for this purpose. CH0 might be running at too high frequency for your glow plug control electronics.
[ 3 posts ] |
Users browsing this forum: No registered users and 14 guests |
