Spirit System
NITRO SETUP
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=6305
Author:  raceboy1 [ Sun 29. Dec 2024 16:00:41 ]
Post subject:  NITRO SETUP
I currently have four of my Heli's using Spirit GT
But I ran into a problem in setting up one of my Nitro's that I use a switch to activate the Remote Glow from my Spektrum Transmitter
I'm using SRLX
I can't find a way to use one of the Aux Channels on the Spirt Gt FLB , for activating by a switch
I know that in the function list there's an Output to Aux 2.
I don't use Banks, so is there a way to re assign the Bank Channel
The other way that I've found is using Channel 5 on my AR6610t receiver that I'm using. Which goes to INH when I setup my Gyro. But not sure if re assigning channel 5 would effect the gyro or not.
Author:  Mattes61 [ Sun 29. Dec 2024 20:19:42 ]
Post subject:  Re: NITRO SETUP
if you want to use an Output to Ch 0 ord AUX2 you must activite throttel-channel in the Spirit to Channel 1 -
I am not shure at the moment which channel you can activate that's what you have to test it, I believe it was ch0 but not shure - one channel works at 60hz at standard, like the throttlechannel 1 -
If you don't actvate the throttle-channel the outputs will not work -
Author:  ZeXx86 [ Mon 06. Jan 2025 8:40:27 ]
in the General - Channels window you can set F: Output to AUX2 or CH0 function. This will output signal from selected channel to the Spirit port.
It can be used for controlloing Glow Plug.
I recommend to use AUX2 port for this purpose. CH0 might be running at too high frequency for your glow plug control electronics.
http://www.phpbb.com/
