It is currently Thu 03. Apr 2025 14:25:34
Page 1 of 1
[ 3 posts ] |
Author |
Message |
raceboy1
Posted: Fri 20. Dec 2024 1:17:45 |
Can the Hard Deck be Activated using the GT FBL without having the GeoLink installed and if so How ??
Top |
msromike
Posted: Fri 20. Dec 2024 3:47:03 |
I'm new to this, but that is the Rescue (Automatic) function. When you trigger it, the GT stores the altitude and performs the rescue maneuver. As long as you keep the channel high (switch on) when you drop below that altitude it triggers again automatically. You cancel it by setting the channel low. If you want to set a new altitude, to replace the one that is in effect, you flip the switch OFF and ON. It will store the new altitude and perform the rescue maneuver once again. To land you have to flip the switch off. You can poke around in the receiver channel mapping screen under channels and check it out.
But to answer your question. The rescue, stabilization modes and coax mode work on a combination of barometric pressure and the IMU. They do not require the Geolink.
Top |
ExCCHP
Posted: Fri 20. Dec 2024 7:49:04 |
Joined: Wed 12. Jan 2022 17:00:01 Posts: 79 Location: British Columbia, Canada
Top |
Page 1 of 1
[ 3 posts ] |
Who is online |
Users browsing this forum: No registered users and 11 guests |
