It is currently Sat 23. Nov 2024 0:11:12
[ 5 posts ] |
scornflake
Posted: Mon 01. Jun 2015 10:10:20 |
With the new update, if we now use the Spirit Gov & we've already got revo mix in place, will this require any reduction?
I've not actually had a chance to fly with the gov enabled yet, but thought I'd ask in case it's something I should keep in mind.
Posted: Mon 01. Jun 2015 13:23:34 |
Normally we do not recommend using revomix at all, but it is likely that our governor can have positive impact on the rudder performance so revomix value may be decreased.
smgunn
Posted: Fri 05. Jun 2015 14:49:32 |
I did have to start using the revo mix when I started using the gov. But the heli is locked in solid. I'm very happy with it
Djg24
Posted: Sat 06. Jun 2015 23:47:49 |
I had the opposite. I was using 1-2 points of revo mix before setting up the governor. Once I set up the governor, I got rid of all revo mix and the tail is as rock solid as anything I've ever flown.
smgunn
Posted: Mon 22. Jun 2015 0:51:23 |
After tuning the gov a little more I've reduced the revo mix. Though the governor sounded like it was holding the head speed great I was still able to raise the gov response a little more and now the tail hardly kicks at all in a full pitch pumps and tick tocs. Goblin 380 KDE500XF-925-G3 HobbyWing 100a Platinum V3 KST-315MG/KST-515MG @8.4v 21t pinion Headspeeds: Norm=2700, IU1=3000, IU2=3250 rpm Gov Response 7 Holding performance 4 I couldn't be much happier with my Spirit.
[ 5 posts ] |
Users browsing this forum: No registered users and 56 guests |
