Spirit System
Cyclic ring 20 degrees?
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=6274
Author:  Konrad [ Fri 29. Nov 2024 14:31:07 ]
Post subject:  Cyclic ring 20 degrees?
I can set the cyclic ring to 20 degrees without mechanical problems when pitch is set to +/- 13 degrees.
I doubt that this makes sense aerodynamically. The motor would probably be overloaded at such a high angle of attack and the airflow on the rotor blade would possibly break off. Should I still set the cyclic ring to the maximum possible value?
Author:  ZeXx86 [ Tue 03. Dec 2024 11:15:40 ]
Post subject:  Re: Cyclic ring 20 degrees?
It should be set to a maximum possible angle that the manufacturer permits for the model. 20° is way over capability of the most models even if mechanics will allow it. It can cause boom strike with a bigger models.
10 - 12° are fine for the most pilots. Please dont forget that when collective pitch and cyclic pitch are maxed out, it could achieve 30° easily.
Author:  Konrad [ Thu 12. Dec 2024 19:58:27 ]
The same question arises for the tail rotor blades. The mechanical limits allow angles of attack for the tail rotor blades that are probably much too high. I currently have 35° on the right (against rotor torque) and 19° on the left. The asymmetry is due to stop behavior. Mechanically, +/- 40° and more would be possible, but that seems too much to me. Would you agree?
I suggest that the tuning tips in the manual be supplemented with information on the meaningful limits.
http://www.phpbb.com/
