Spirit System
setup Wizard question
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=6245
Author:  Renzo [ Thu 31. Oct 2024 23:07:27 ]
Post subject:  setup Wizard question
Hallo All,
Do the 6 degrees have to be positive? in my setup Wizard I have -6 degrees is it right?thanks everyone for your help
Author:  ExCCHP [ Fri 01. Nov 2024 1:49:32 ]
Post subject:  Re: setup Wizard question
Which blade are you using to take the angle measurement?
Are the blades aligned with the boom?
AFAIK you should always take measurements with the blade over the nose of the canopy.
Author:  HeliMLM [ Fri 01. Nov 2024 7:43:00 ]
it does not matter if you take the blade over the boom or over the nose. and depending on the pitch gauge you are using and how it was zeroed and which blade you are using, there could be + or - 6°.
Author:  Renzo [ Fri 01. Nov 2024 12:38:18 ]
Tank for your help...i can go fly:)
Author:  franz88 [ Fri 01. Nov 2024 13:17:51 ]
don't get confused
It doesn't mean 6 degrees of cyclic
6 degrees in the geometry
and in cyclic ring supported degrees from your mechanics helicopter (about 10 degrees)
http://www.phpbb.com/
