It is currently Thu 03. Apr 2025 14:50:27
Page 1 of 1
[ 5 posts ] |
Author |
Message |
Renzo
Posted: Thu 31. Oct 2024 23:07:27 |
Hallo All, Do the 6 degrees have to be positive? in my setup Wizard I have -6 degrees is it right?thanks everyone for your help
Top |
ExCCHP
Posted: Fri 01. Nov 2024 1:49:32 |
Joined: Wed 12. Jan 2022 17:00:01 Posts: 79 Location: British Columbia, Canada
Which blade are you using to take the angle measurement? Are the blades aligned with the boom? AFAIK you should always take measurements with the blade over the nose of the canopy.
Top |
HeliMLM
Posted: Fri 01. Nov 2024 7:43:00 |
it does not matter if you take the blade over the boom or over the nose. and depending on the pitch gauge you are using and how it was zeroed and which blade you are using, there could be + or - 6°.
_________________ cheers Michael
Top |
Renzo
Posted: Fri 01. Nov 2024 12:38:18 |
Tank for your help...i can go fly:)
Top |
franz88
Posted: Fri 01. Nov 2024 13:17:51 |
don't get confused It doesn't mean 6 degrees of cyclic 6 degrees in the geometry and in cyclic ring supported degrees from your mechanics helicopter (about 10 degrees)
Top |
Page 1 of 1
[ 5 posts ] |
Who is online |
Users browsing this forum: No registered users and 9 guests |
