[SOLVED] Rp3-h elrs receiver. No telemetry values. https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=6194 |
Page 1 of 2 |
Author: | frisos@gmx.co.uk [ Sun 08. Sep 2024 21:02:43 ] |
Post subject: | [SOLVED] Rp3-h elrs receiver. No telemetry values. |
Hello, I recently bought a Radiomaster rp3-h elrs receiver to work with my spirit gt unit. I connected it through the crsf connection. When discovering telemetry sensors, i get to see the spirit sensors in edge tx, but al the values stay at 0. I do get working telemetry from the sensors of the rp3-h itself though. I run elrs via the Ranger micro in my tx16s on Edge tx v2.10.2. My elrs firmware on the tx and rx are 3.4.3. On the Spirit gt i run firmware 3.7.0. I would really like to have working telemetry from the Spirit unit as well and cannot find out what the problem seems to be… |
Author: | ZeXx86 [ Tue 10. Sep 2024 14:39:09 ] |
Post subject: | Re: Rp3-h elrs receiver. No telemetry values. |
Hello, we received this receiver today and will check how it works. I will let you know soon. We will make sure telemetry will work properly for upcoming update (likely next week). |
Author: | franz88 [ Tue 10. Sep 2024 19:19:27 ] |
ZeXx86 wrote: Hello, we received this receiver today and will check how it works. I will let you know soon. We will make sure telemetry will work properly for upcoming update (likely next week). zexx86 please in the next update you can increase the numbers of flight style? 4 is too sweet and the 5 it's too fast. Mybe add the decimal 4,1/4,2 ecc so we don't change the setup of the others thanks |
Author: | Habásek [ Wed 11. Sep 2024 7:10:58 ] |
franz88 wrote: ZeXx86 wrote: Hello, we received this receiver today and will check how it works. I will let you know soon. We will make sure telemetry will work properly for upcoming update (likely next week). zexx86 please in the next update you can increase the numbers of flight style? 4 is too sweet and the 5 it's too fast. Mybe add the decimal 4,1/4,2 ecc so we don't change the setup of the others thanks I think this setting has been in SW for several years and I would not change it. Use expo in your transmitter. I see the difference between 4-5 as very, very small. |
Author: | ZeXx86 [ Wed 11. Sep 2024 7:40:06 ] |
franz88 wrote: ZeXx86 wrote: Hello, we received this receiver today and will check how it works. I will let you know soon. We will make sure telemetry will work properly for upcoming update (likely next week). zexx86 please in the next update you can increase the numbers of flight style? 4 is too sweet and the 5 it's too fast. Mybe add the decimal 4,1/4,2 ecc so we don't change the setup of the others thanks Flight Style is not changing speed at all. The most pilots can't distinguish difference between 1 and 4. Can you describe what difference you can see or what you wish to achieve? Please do this in other thread, this thread is for different question. |
Author: | underscore [ Wed 25. Sep 2024 2:02:07 ] |
I'm having the same problem: Using a BetaFPV ERLS Lite receiver (had one on my desk for testing, plan was to switch to RP3-H ultimately) running ELRS 3.5. The transmitter discovers the following sensors: RxBt, Curr, Capa, Bat%. But the values never update (and I get the "sensor lost" warning). Is there anything I can help debugging? |
Author: | ZeXx86 [ Thu 26. Sep 2024 5:43:08 ] |
Thank you for your report. Today we might finish required changes to make ELRS compatibility better. We have the setup working with RP3-H now. Anyone interested can write me a message to get faster access to the firmware update. |
Author: | ZeXx86 [ Fri 27. Sep 2024 9:47:17 ] |
The problem seems to be resolved completely. Additionally we will have CRSF/ELRS integration fully working soon too. |
Author: | frisos@gmx.co.uk [ Mon 30. Sep 2024 10:34:33 ] |
Post subject: | Re: [SOLVED] Rp3-h elrs receiver. No telemetry values. |
Thats great news! Thank you for being so accessible to your customers! Looking forward to the integration too! |
Author: | frisos@gmx.co.uk [ Mon 28. Oct 2024 9:24:02 ] |
Sadly flashing the spirit gt to 3.7.1 did nothing for my telemetry problem. Nothing changed. I've deleted all the sensors in the tx16s and re-discovered them. I get 3 sensors: esc amp, batt %, batt cap. But al values remain zero. |
