It is currently Sat 03. May 2025 22:25:58
PostPosted: Tue 16. Jul 2024 18:28:42
Good day,
I was in the process of updating my Spirit GT to V3.0.7 when the software gave and error aborting the upgrade, I have followed the instructions to use recover mode to reflash, which the software does, but the unit still is not detected after the recovery mode reflash.
I use a Macbook M3 Pro Max, with the sub connection.
The light flashes during the flash process, but then afterwards stay solids blue, but does not work. Also tried the android and iOS apps, but nothings works.
Any advice?
PostPosted: Wed 17. Jul 2024 7:49:03
I am not sure what happened, but for sure it can be fixed.
I will only need to know serial number of your unit - if you have Spirit paper box. Or if you do not have it, please send file called .spirit.flash.cfg located in your Documents directory.
Please send it to me by email or a private message.
Then I will let you know next steps.
PostPosted: Wed 17. Jul 2024 9:39:34
Thank you,
Serial Number: *****
Users browsing this forum: No registered users and 19 guests
