Advice on low head speed setup (Gaui X7) https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=615 |
Page 1 of 1 |
Author: | johncclayton [ Wed 22. Apr 2015 21:01:19 ] |
Post subject: | Advice on low head speed setup (Gaui X7) |
Hi I want to put a Spirit on my Gaui X7. It's presently running Bavarian Demon. I am using a Kosmik ESC at 60% throttle with standard gears to achieve about 1560 head speed - which I enjoy greatly. In putting a Spirit on a machine with low head speed - are there any settings I should change specifically to help with a low head speed setup? Thanks -- John Clayton |
Author: | ZeXx86 [ Thu 23. Apr 2015 7:11:44 ] |
Post subject: | Re: Advice on low head speed setup (Gaui X7) |
Hi, you can play with Cyclic Gain, Elevator Filter (it shouldn't be too high) and if you will observe some bouncing then you can decrase Geometry 6°. With these parametres it should be possible to tune it perfectly to any RPM. |
