Unable to compass calibrate https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=6119 |
Page 1 of 1 |
Author: | raceboy1 [ Wed 05. Jun 2024 2:58:43 ] |
Post subject: | Unable to compass calibrate |
Getting real frustrated with this system, I’m switched this Heli from an Ikon I have it all set up, but I can not get thru the Compass Calibration The Firmware was flashed to Current Here’s the process that I did S elected set level Tab Selected the Calibration Tab Powered down the heli Went outside Repowered up the Heli with the transmitter And at that point I get a solid Greed light on the GeoLink The manual says I should get a rapid flashing Blue light This never happens So what is going on |
Author: | 10x [ Wed 05. Jun 2024 8:17:26 ] |
Post subject: | Re: Unable to compass calibrate |
Have you tried going out side without powering down the heli? Just a thought... |
Author: | ZeXx86 [ Wed 05. Jun 2024 14:32:29 ] |
Hello, rapid blue flashing on the GeoLink should be there only when moving with module. In any case if you will power on the GeoLink for 3 times without successful callibration it will return back to previous calibration. Then you have to click at the Calibration Request button again. |
