It is currently Tue 08. Apr 2025 11:40:39
PostPosted: Wed 29. May 2024 22:04:01
Please explain to me the calibration process Align RCE-BL70G ESC.
Now the parameters are: frequency 50Hz, minimum 1100us, maximum 1900us.
I tried to calibrate this ESC with a separate BEC but I'm not sure if this is correct.
PostPosted: Thu 30. May 2024 7:30:25
https://manual.spirit-system.com/index.php?title=Governor
Perform the calibration as for other models and according to the regulator manufacturer's manual
The governor must be switched off.
Hz for Align is from 50 to 200.
https://www.align.com.tw/ManuaLib/Heli/esc/RCE-BL70G_en.pdf
PostPosted: Thu 30. May 2024 11:13:00
calibration with other BEC is not needed, it could actually even damage the ESC if BEC is not connected correctly according Align manual.
Calibration can be done in the very same way as per their ESC manual. However if it is new ESC, you will rather not need calibration at all.
If the ESC is connected directly to the Spirit unit then the only thing you will need is to assign Throttle output to Channel 1.
I dont know what is your Spirit unit or wiring or receiver so it is hard to help more.
PostPosted: Thu 30. May 2024 20:56:46
Unfortunately, there is nothing in the instructions for my ESC about calibration.
Can I set the frequency to 200Hz for it?
PostPosted: Thu 30. May 2024 21:03:53
I used a separate BEC, but turned off the BEC in the ESC, leaving only the signal cable. Otherwise, the ESC starts before it can enter the calibration mode.
I have Spirit GT, now the ESC cable is plugged into the AUX1 connector, Throttle output to Channel 1, ESC is not new, used.
PostPosted: Sun 02. Jun 2024 7:45:02
If Spirit Governor is turned off then you can calibrate the ESC with the most brands by initializing with full throttle - throttle curve set in the radio to 100%.
Then after confirmation beeps you will set throttle to 0% and calibration is finished.
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
