Spirit System
How configure a futaba t8fg with PWM
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=610
Author:  cxseba [ Tue 21. Apr 2015 22:08:54 ]
Post subject:  How configure a futaba t8fg with PWM
Hi.
I have a Align 450L dominator with futaba T8fg and receiver R617FS.
First, this is PWM? Or I can select PPM?
I have problems with the bank and rescue mode.
In this mode only can select the channel 5 for banks and gyro unassigned.
How is the correct configuration to put the bank in 3 position switch and rescue mode in an other 2 position switch?
Thank
Author:  ZeXx86 [ Tue 21. Apr 2015 22:54:29 ]
Post subject:  Re: How configure a futaba t8fg with PWM
you can check our Futaba Guide here: viewtopic.php?f=20&t=579
Basically you can switch flight modes so that it can switch the banks and at the same time momentary switch will be IDLEUP2 with the higer priority.
Bank 0 = conventional flightm ode - NORMAL
Bank 1 = for example stabilisation mode - IDLEUP1
Bank 2 = rescue - IDLEUP2
Author:  cxseba [ Tue 21. Apr 2015 23:57:11 ]
Thank you for your quick response.
For this setup I need select the bank in channel 5 thath´s ok?
in this case if I put in switch SG 3 position -NORMAL
-IDLEUP 1
-IDLEUP 2
and in the swith SH 2 position with priority -IDLEUP 3 ( for rescue ) works ok??
other option:in the radio is possible to change in the radio the AUX to channel 5 for the banks.
Thank you again.
Author:  ZeXx86 [ Wed 22. Apr 2015 7:47:45 ]
Yes you are right.
But there are 3 banks so it is enough to have just 3 flight modes where on of them is assigned for the rescue.
So IDLEUP3 is not needed, but can be used too.
So gyro gain will determine what bank you want to select. It can be configured in this way:
Flight mode: NORMAL - GYRO 0% AVCS
Flight mode: IDLEUP1 - GYRO 0% AVCS
Flight mode: IDLEUP2 - GYRO 100% AVCS
Flight mode: IDLEUP3 - GYRO 100% NORM (for the rescue)
http://www.phpbb.com/
