Rescue Duration https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=6093 |
Page 1 of 1 |
Author: | buttles [ Sun 19. May 2024 18:31:59 ] |
Post subject: | Rescue Duration |
Hi, playing around with Rescue (Normal) today. Tried the Rescue Duration to see how it performed. Then tried to un-tick it but it stays checked. Hopefully something simple to fix but am stumped!! A basic search didn't come up with anything. Thanks |
Author: | Mattes61 [ Mon 20. May 2024 11:17:49 ] |
Post subject: | Re: Rescue Duration |
Hello, have you really saved the un-ticked configuration or only changed but not safed ? Sometimes you just forget that in a hurry - Another thing have you banks activatet then un-tick them in all banks - Regards |
Author: | buttles [ Mon 20. May 2024 12:48:44 ] |
The autosave function is active but I also backed that up with a manual save. Alas, the same. Been through all 3 banks and it also doesn't clear the tick. Tomas will have to confirm how that particular function is handled I think |
Author: | Mattes61 [ Mon 20. May 2024 13:24:27 ] |
Hello, one thing will work, I have it no tried but it should - Disable all settings (function) in all three banks so that you have no stabi - save this settings in your FBL - then power up new the FBL, then there must be stabifunction disabled in all banks - Then set all banks again as you want and safe it in your FBL - start the FBL new (new power up) an look if all setting are like you wanted - If that doesn't work then there must be something wrong and then Tomas has to look what kind of problem that can be - Hint: I personally dislike autosave and save all manually but that's only my humble opinion - Regards |
Author: | buttles [ Tue 21. May 2024 7:43:34 ] |
Thanks for your suggestions. It's not my Heli so can't access it at the moment. We did disable the Stabi functions, save then re-enable Stab normal. This is using the latest software in an old Red unit. |
