Telemetry cable resistor for high voltage? https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=6070 |
Page 1 of 1 |
Author: | Schmarfield [ Sun 28. Apr 2024 14:12:16 ] |
Post subject: | Telemetry cable resistor for high voltage? |
The manual says to use a 10k Ohm resistor in the telemetry cable adapter (this is for Castle Creations), but says a different value may be needed above 7v if readings are unstable. If I’m going to run 8v BEC should I start with a different value? Thank you. |
