It is currently Fri 22. Nov 2024 6:58:58
PostPosted: Sun 28. Apr 2024 14:12:16
The manual says to use a 10k Ohm resistor in the telemetry cable adapter (this is for Castle Creations), but says a different value may be needed above 7v if readings are unstable. If I’m going to run 8v BEC should I start with a different value?
Thank you.
Users browsing this forum: Bing [Bot], Uplate and 34 guests
