Spirit System
spirit gt S.BUS
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=6046
Page 1 of 2
Author:  franz88 [ Mon 01. Apr 2024 14:03:24 ]
Post subject:  spirit gt S.BUS
I have to connect spirit gt with frsky x8r with s.bus and connect at my tx16s mk2 max.
To have no problems with the system flybarless how should I do this?
I create Pitchcurve and this curve it is better to associate at page INPUT or at page MIXER ? (can be associated as you wish)
pitch curve must be associated only on channel 6? (channel pitch)
there are multiple methods but I want to use the correct system
Author:  Mattes61 [ Tue 02. Apr 2024 10:40:30 ]
Post subject:  Re: spirit gt S.BUS
look at Futaba-SBus in Manual:
https://manual.spirit-system.com/index. ... S_RECEIVER
In my opinion you have to take at Mixer the pitch curve and other curves you need -
Input represents only your inputs as sticks and/or switches or other channels, there can be made some expo or reduced throws - Nothing special -
In EdgeTX/OpenTX you have many different ways to do some tasks and there are not really false ways to do it, it is only personel preference -
Author:  franz88 [ Tue 02. Apr 2024 14:19:29 ]
The attachment Screenshot 2024-04-02 112741.png is no longer available
Thanks for your answer to my question.
receiver frsky x8r Zexx86 she has arrived.
I connect with S.BUS to spirit gt and in the software spirit i set futaba s.bus
But the binding with receiver I have to create it in mode frsky
Author:  ZeXx86 [ Wed 03. Apr 2024 19:24:15 ]
Yes, this is all correct.
Use Futaba S.BUS receiver type in the Spirit Settings.
In radio use FrSky D16 modulation.
Author:  franz88 [ Tue 09. Apr 2024 22:38:27 ]
zexx86 fix a problem in the software.
To remind me of the order of the settings in demo mode i entry in wizard mode but at step4 when I press connect instead of going out unit status "DEMO MODE" the message goes out "status not found" and I can't go on.
I'm in demo mode is normal that no spirit is connected.
Listen me, in diagnostic I have the green bar movement Rudder in the correct direction
on the right the green bar when I move the stick to the right
on the left the green bar when I move the stick to the left
but the movement of the servo tail it's incorrect.
If the green bars are moving in the right direction the movement of the servo shouldn't that be correct?
Author:  HeliMLM [ Wed 10. Apr 2024 7:01:45 ]
just follow the setup process step by step as per manual / wizzard: first the green bars have to be correct direction > this means TX>Spirit is set up correctly. next step in the setup is the servo reversals > here you would i.e. reverse the tail servo if direction is wrong.
Ciao
Michael
Author:  franz88 [ Wed 10. Apr 2024 9:09:34 ]
Ciao
Michael
If I move end point on my radio for you I have to run it again the re-calibration esc ? (Min stick and max stick )?
Author:  ZeXx86 [ Wed 10. Apr 2024 19:37:18 ]
First- all endpoints should be +/- 100% in Diagnostic tab. Not more. Spirit will not ouput more tan what is set as Range.
But it is better to recalibrate to be sure it is OK - with Spirit Governor Off.
Or even better if ESC is resetted there is no need to calibrate with Spirit.
Only set 1100 - 1940us in Spirit and it will match perfectly.
Author:  franz88 [ Wed 10. Apr 2024 21:14:11 ]
https://manual.spirit-system.com/index.php?title=Governor
in this page if you click on the item "HobbyWing RPM Sensor" the link it does not work
PS
i connect esc and motor (with end point radio modified for have 0/100 on software spirit) and everything works fine.
Author:  franz88 [ Sat 13. Apr 2024 7:44:49 ]
I would like that if my helicopter loses radio signal return home of the geolink is activated.
I would like to use the spirit failsafe although I don't understand how it works.
The failsafe spirit takes into consideration channel 7 if i use channel 7 for activate return to home?
or failsafe spirit does it only consider channels 1 to 6?
However if I activate it after Can I never turn it off again?
I saw that there is a button to activate failsafe in channels but I don't see a way to deactivate it?
Why if I don't like how he behaves I would like to deactivate it Instead if everything behaves the way I want only in that case I'll leave it on.
I have to do some tests before I can fly
http://www.phpbb.com/
