RPM Signal sometimes 0 https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=6031 |
Page 1 of 1 |
Author: | ZeXx86 [ Tue 19. Mar 2024 16:04:25 ] |
Post subject: | Re: RPM Signal sometimes 0 |
Helo, log is showing RPM cable signal. Can you disconnect the RPM cable and check again the log? This problem could happen if signal is very weak or there is interference. It must be routed carefully, not near a source of interference. |
Author: | flo [ Fri 29. Mar 2024 14:00:44 ] |
OK - it works fine with RPM disconnected and just the telemetrie data. I suppose it must be the RPM Copler Mudle from the hobbywing esc |
