It is currently Sun 24. Nov 2024 10:55:24
Post new topic Reply to topic  [ 4 posts ]
PostPosted: Sun 17. Mar 2024 13:33:34
Hi!
I have NX8 transmitter (v3.13), SPM9747 and Spirit 2. I want to configure the FBL system from the transmitter, but I cannot enter the menu.
The instruction:
https://manual.spirit-system.com/index. ... ntegration
says:
Quote:
https://manual.spirit-system.com/index.php?title=Spektrum_IntegrationStart the transmitter and on the main screen use a roller - rotate to the right until you will see a Blank screen.
With NX-series Blank screen will appear only once you will open the Integration menu.. Proceed with following section Entering the menu and then use Roller to scroll one more page.
But I cannot do any of them. Actually I cannot find the integration menu in the transmitter :oops:
Could you help me? Thanks!
PostPosted: Sun 17. Mar 2024 13:59:42
it is really easy but if you not know exactly you get frustrated -
Do it like that:
put the right and the left stick in the inner side downwards as in the manual described and then roll the roller at the same time to the right, then you get the integration menue of spektrum, that's it !
Maybe it would be good to write that in the online manual because this questions are really often -
This "problem" is only by the new transmitters NX6, NX8, NX10 and so on...
PostPosted: Sun 17. Mar 2024 14:57:33
I thank you very much for this tip!
I had given up on the idea of ​​being able to access it since I received my new NX10 few months ago ...
Kind regards.
Hervé
PostPosted: Mon 18. Mar 2024 17:12:40
Do it like that:
It works! Many thanks!
Users browsing this forum: No registered users and 53 guests
