It is currently Sat 23. Nov 2024 11:51:16
Post new topic Reply to topic  [ 4 posts ]
PostPosted: Thu 07. Mar 2024 19:51:16
I try to use the AUX-Port of my Spirit RS (Firmware 3.6.2) to switch the IISI Safety Caps 3x50F (Buffer). In the channel assignment of the Spirit settings I use the function "F: Output to AUX" and "Channel 8". The switch works but the safety caps are not switchable when the main battery is disconnected. Any suggestions to solve the problem?
Thank you for your support
Greetings Manni
PostPosted: Thu 07. Mar 2024 21:59:50
Hi Manni
i am well using the same (on GTR in my case) to switch IISI safety caps. working great.
did you try with i.e. a servo connected to the AUX port if the switch is really working? did you program the IISI cap to switch off by channel? i do not remember in detail, but by default this was off iirc. and the servo travel should really be 100% as well.
cheers
Michael
PostPosted: Fri 08. Mar 2024 9:17:18
Hello Michael,
yes it works. It was my mistake. The switch didn't work correctly. Now it's okay. Many thanks.
Greetings
Manni
PostPosted: Fri 08. Mar 2024 11:56:04
... great it's working for you! :)
cheers
Michael
Users browsing this forum: No registered users and 51 guests
