It is currently Sat 23. Nov 2024 0:20:59
Page 1 of 1
[ 7 posts ] |
Author |
Message |
Pete678
Posted: Sun 03. Mar 2024 17:45:47 |
I've gone through and programmed all my servos into the unit and set all for zero degrees at middle stick and I have all the correct movement and stabilisation correction set but, when I come to set the 6 degree of pitch it goes into a negative pitch, but if I move the blade to the side 90 degrees to the boom it is perfect at 6 degrees. I know in the wizard it says to do it parallel to the boom but like I say it comes at a negative pitch. The only thing I can think of is that I may have mixed up the pitch and aileron servo the wrong way maybe? Any help would be great. .Thanks
Top |
ExCCHP
Posted: Sun 03. Mar 2024 21:52:59 |
Joined: Wed 12. Jan 2022 17:00:01 Posts: 71 Location: British Columbia, Canada
Are you measuring the blade Over the tail boom or the blade in the front?
I believe you are to use the blade over the front of the heli for All measuring.
Top |
Pete678
Posted: Sun 03. Mar 2024 22:24:42 |
I've set a couple up before and I always do the measuring over the front and then make sure the rear is the same for mechanical purposes. I get negative pitch when it goes into the 6 degree set up mode. Haven't had it before do that's why I think I ,may need to go through the wizard again and switch ail and ele around and configure from there
Top |
senaka
Posted: Mon 04. Mar 2024 9:36:32 |
Joined: Wed 10. May 2023 9:36:53 Posts: 37 Location: The Netherlands
I would redo the wizard by first setting it back to factory defaults, and taking it from there.
Top |
Posted: Mon 04. Mar 2024 9:39:45 |
Site Admin |
it might not indicate any issue. At the front you could get negative but at the rear it will be positive. It depends at which side you are measuring.
Top |
Pete678
Posted: Mon 04. Mar 2024 11:05:39 |
so If I measure at the back and get 6 degrees then it will be fine as all the functions work as they should? Thanks
Top |
Posted: Mon 04. Mar 2024 11:12:02 |
Site Admin |
Yes, correct.
Top |
Page 1 of 1
[ 7 posts ] |
Who is online |
Users browsing this forum: No registered users and 63 guests |
