Spirit System
Tail Rotor
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=6009
Author:  Duckman [ Tue 27. Feb 2024 11:55:07 ]
Post subject:  Tail Rotor
Hi
Just at take off head speed the tail rotates quicly to the right in a full circle. The servo direction is OK and the blades move smoothly. Any ideas of what the problem is?
Author:  senaka [ Mon 04. Mar 2024 11:32:04 ]
Post subject:  Re: Tail Rotor
Could be in the config although moving the TX sticks commands the correct throw direction, the spirit may have this direction reversed somewhere in the settings?
Author:  ZeXx86 [ Mon 04. Mar 2024 11:36:10 ]
It could be also wrong Mounting Position configuration.
Servo must compensate in the correct direction otherwise model will yaw everytime during lift off.
You can check it without main blades when you will set low RPM and carefully change position.
If it will not try to hold then General/Mounting position was set to incorrect one.
It is better to hold tail boom very firmly and carefully. Very low RPM are enough to check this.
http://www.phpbb.com/
