It is currently Fri 22. Nov 2024 19:17:26
PostPosted: Mon 27. Apr 2015 17:31:26
when i fly a looping with my voodoo600 (HT Ninja Blades) it always happend that in the first section 0-30° the voodoo make a jump to 90°. I don t know if this is call bouncing.
Its like a heavy gust of wind.
I try elevator filter (value 2) but nothing happend (the first value was 0). Shall I increase to 4 or is there any other value to change?
Regards Jens
PostPosted: Mon 27. Apr 2015 19:52:24
mostly this phenomenon is caused when there is not necessary cyclic pitch available. As the solution I recommend to configure Cyclic Ring - Aileron / Elevator range as high as mechanically possible without any binding. Alternatively you may try to decrease collective pitch.
Elevator Filter is not intended for the issue, so you can keep at the previous value.
Users browsing this forum: 10x and 74 guests
