It is currently Fri 22. Nov 2024 5:54:30
PostPosted: Sun 18. Feb 2024 23:23:08
Hi, i installed 3.6.2 and i tried to load a .4ds file saved in a older version and nothing happens.
It's using SRXL2 and the menu stays in PWM and i don't get any error or the file is not converted to the new version. I am sure i was able to load saved version in demo mode to look at the settings.
Did i miss anything. I don't know how to grab a older windows version to test.
Thanks i uploaded my saved file
2juil12-23.4ds [255 Bytes]
Downloaded 70 times
PostPosted: Sun 18. Feb 2024 23:29:54
This is a update to my first post.
I found a windows version 3.6.1 and reinstalled. When i use demo mode with the .4ds file it loads and displays the right configuration.
PostPosted: Tue 20. Feb 2024 11:28:12
the settings are not loaded in Demo mode only in 3.6.2, because there are bigger differences inside from 3.6.1.
However in 3.6.3 it will work again.
With connected unit you can load settings normally with all versions.
PostPosted: Tue 20. Feb 2024 16:54:21
Thanks Thomas for the reason,
Will the old files be upgraded when loaded in the 3.6.3 version or I should keep a old win version if I want to o back and check a setting. I really use that feature to see changes it my settings.
Envoyé de mon iPhone en utilisant Tapatalk
Users browsing this forum: No registered users and 12 guests
