It is currently Sat 23. Nov 2024 5:00:06
 Post subject: [SOLVED] 3.6.0 on Linux
PostPosted: Sun 03. Dec 2023 16:53:33
I can not execute settings.sh on Linux Mint for some reason. Also unable to install directly from terminal.
 Post subject: Re: 3.6.0 on Linux
PostPosted: Sun 03. Dec 2023 17:32:14
Please try to download this ZIP file, extract the archive into the spirit settings folder - there is new settings.sh for launching the software.
I hope it will help you.
If not, please send me output from the terminal that you can see after starting the spirit settings.
What version of Linux Mint do you have? We will try it now on clear installation.
settings.zip [524 Bytes]
Downloaded 64 times
PostPosted: Sun 03. Dec 2023 17:39:54
I have Linux Mint Cinnamon. The therminal will open and close immediately when I try to execute the file. Yes, all files were unzipped to a folder.
PostPosted: Sun 03. Dec 2023 17:43:10
Just tried that. Settings.sh will not open when try "Run" or "Run in Terminal"
PostPosted: Sun 03. Dec 2023 18:06:29
My bad. I overlooked the attached ZIP file you provided. Yes, it WORKS now! Thank you very much for your help.
PostPosted: Sun 03. Dec 2023 18:18:23
Perfect, the fix will be available in upcoming update.
We are glad for each Linux user ;)
PostPosted: Sun 03. Dec 2023 18:24:25
I know exactly what you mean. Don't get me started to write about windows..... :D
Users browsing this forum: Bing [Bot] and 49 guests
