Spirit System
Wobbles on slow tic toc
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5845
Author:  dkpodder [ Mon 16. Oct 2023 15:17:37 ]
Post subject:  Wobbles on slow tic toc
Running the GTR in my Oxy5 with BK5001HV servos.
When doing slow tic tocs (just learning), the cyclic wobbles a bit at the stops, and then settles rather quick.
Is this normal behavior, or am I able to tune this out?
Thinking of replacing the servos for either Theta DH1 or some Nexpor's. Any advice on this?
Author:  Mattes61 [ Mon 16. Oct 2023 15:39:07 ]
Post subject:  Re: Wobbles on slow tic toc
I had the same problem a longer time ago with my SAB Fireball -
What helps was the reducing of the headgain - for example per step max -5 points per setting till all was fine -
Author:  ZeXx86 [ Mon 16. Oct 2023 18:30:13 ]
You can increase Elevator Filter to 3 - 4.
Author:  dkpodder [ Mon 23. Oct 2023 15:58:12 ]
Thank you, I will try both suggestions.
http://www.phpbb.com/
