[SOLVED] Can’t enable rate mode https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5844 |
Page 1 of 1 |
Author: | RotoRotoR [ Sun 15. Oct 2023 23:32:56 ] |
Post subject: | [SOLVED] Can’t enable rate mode |
Spirit 2 with PWM receiver (Sanwa Airtronics) My rudder is stuck in heading hold. I have set the gyro to a three position switch on Aux 1. The switch uses +75, -50, and -100. I have the stabi function set to switch and channel 5 in the Spirit settings app. I read that negative value should enable rate mode. What am I doing wrong? Sent from my iPhone using Tapatalk |
Author: | RotoRotoR [ Mon 16. Oct 2023 4:34:29 ] |
Post subject: | Re: Can’t enable rate mode |
Correction: I have the gyro set to channel 5. Stabi function is set to channel 7 and aux 2 for rescue normal. Sent from my iPhone using Tapatalk |
Author: | Mattes61 [ Mon 16. Oct 2023 15:51:32 ] |
Hello, if you don't have stabi mode enabled then a gain for example -50 is rate mode and +50 is heading hold mode - If you use an stabi mode then only some modes have rate mode as you see here in the manual: https://manual.spirit-system.com/index.php?title=Configuration#STABI_TAB Regards |
Author: | RotoRotoR [ Mon 16. Oct 2023 23:58:52 ] |
Thanks! Got it working now. I had to select stabi/function/selected by channel. This enables stabilization and rescue subtabs. |
