It is currently Fri 22. Nov 2024 12:19:34
 Post subject: Wobbles on slow tic toc
PostPosted: Mon 16. Oct 2023 15:17:37
Running the GTR in my Oxy5 with BK5001HV servos.
When doing slow tic tocs (just learning), the cyclic wobbles a bit at the stops, and then settles rather quick.
Is this normal behavior, or am I able to tune this out?
Thinking of replacing the servos for either Theta DH1 or some Nexpor's. Any advice on this?
PostPosted: Mon 16. Oct 2023 15:39:07
I had the same problem a longer time ago with my SAB Fireball -
What helps was the reducing of the headgain - for example per step max -5 points per setting till all was fine -
PostPosted: Mon 16. Oct 2023 18:30:13
You can increase Elevator Filter to 3 - 4.
PostPosted: Mon 23. Oct 2023 15:58:12
Thank you, I will try both suggestions.
Users browsing this forum: Bing [Bot] and 18 guests
