delay for the tail https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5767 |
Page 1 of 1 |
Author: | Gerrybru [ Sun 30. Jul 2023 18:32:15 ] |
Post subject: | delay for the tail |
What actually happens if I increase or decrease the delay for the tail? What happens at the rear? -Gerald |
Author: | ZeXx86 [ Mon 31. Jul 2023 8:06:31 ] |
Post subject: | Re: delay for the tail |
Hello, this parameter will change Regulation term of the Spirit unit to adapt it for a slower tail servo and/or mechanics. There is inverse releation between servo speed and Rudder Delay parameter. You can use our Servo List for configuring it properly. |
Author: | Gerrybru [ Mon 31. Jul 2023 13:07:38 ] |
OK, thanks for the quick reply, this might help with my EC135 Roban 800 to reduce hunting after a steering deflection. I feel like the mechanics are slow here. The servo itself would be fast enough, but the mechanics just don't allow it. So I would increase the value in steps of 2. What actually happens when the value gets too high? -Gerald |
Author: | ZeXx86 [ Fri 04. Aug 2023 10:00:01 ] |
Hello, tail will start oscillating very fast when it is too high and/or can be hotter or somehow delayed for stick reaction. It is better to keep this value low or according our Servo List if you are unsure. |
Author: | Gerrybru [ Fri 04. Aug 2023 10:56:51 ] |
Hello, good to know, I'll give it a 1, 2 or 3 point higher. I will be careful. Or is there another way to counteract a soft bounce? Iknow the mechanics are probably rather sluggish. I may have to install a stronger servo, but it's actually strong enough at 30kg. -Gerald |
