It is currently Fri 22. Nov 2024 19:02:38
 Post subject: Recovery mode?
PostPosted: Thu 10. Aug 2023 12:56:32
Hi, I'm all set up on Trex 700 with a brand new GT2. Problem: recovery modes are applying negative pitch on triggering with negative gyro gain.. I can't see anywhere in the set up wizard to correct this. Any ideas what I have got wrong? :?
 Post subject: Re: Recovery mode?
PostPosted: Thu 10. Aug 2023 13:43:02
This is happening when the very base settings are not correct.
I recommend to proceed according the Setup Wizard once again, because it is described there step by step to achieve correct settings.
It is one of these:
Mounting Position
Swashplate Type
Servo Reversing
Servo wiring
If any of these or combination of these are not correct it will result in a bad performance and wrong operation, including rescue.
The easiest thing to verify is Diagnostic tab - there channels must move in the right directions, always.
PostPosted: Thu 10. Aug 2023 20:08:05
general - channels
if you lower the pitch curve
the green bar pitc in the software spirit does it go down?
Users browsing this forum: mainstreet and 82 guests
