Servo travel max 15 degrees https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5757 |
Page 1 of 1 |
Author: | nzlsubzero [ Tue 25. Jul 2023 10:15:33 ] |
Post subject: | Servo travel max 15 degrees |
Hi All I have a Spirit 2. I have set up the channel travel from the TX to ensure 100% each way on the diagnostics tab. I'm having an issue with the rudder that the servo won't travel more than about 15deg left or right. Actual tail blade angle changes about 2-3deg. I have adjusted the max travel each way to 200 on the limits tab. No change. The servo is a Futaba S9254 and set it to 1520us and 333Hz. This was checked on Spirit servo list. Thanks for any suggestions. |
Author: | HeliMLM [ Tue 25. Jul 2023 10:18:16 ] |
Post subject: | Re: Servo travel max 15 degrees |
Hi what are your settings on collective pitch and cyclic ring limits (and geometry 6° as well)? are those set @ 200? did you maybe setup some servo travel correction? |
Author: | ZeXx86 [ Tue 25. Jul 2023 11:59:20 ] |
Hello, configuring 200 for endpoints indicate the mechanics need to be changed. Please use longer servo arm, maybe 1-2 holes to be around 120 with endpoints. Some servos can't rotate that much. |
Author: | nzlsubzero [ Wed 26. Jul 2023 6:28:02 ] |
ZeXx86 wrote: Hello, configuring 200 for endpoints indicate the mechanics need to be changed. Please use longer servo arm, maybe 1-2 holes to be around 120 with endpoints. Some servos can't rotate that much. I have the ball on the outermost hole of the tail servo. I adjusted the endpoints to 200 to see if that was the issue, but it isn't. |
Author: | nzlsubzero [ Wed 26. Jul 2023 6:29:04 ] |
HeliMLM wrote: Hi what are your settings on collective pitch and cyclic ring limits (and geometry 6° as well)? are those set @ 200? did you maybe setup some servo travel correction? Hi Michael The tail is the current issue. Cyclic is ok. Thanks |
Author: | HeliMLM [ Wed 26. Jul 2023 6:47:48 ] |
Sorry, it seems i did not read your post carefully enough did you try to connect a different tail servo just for a test? |
Author: | nzlsubzero [ Wed 26. Jul 2023 7:46:23 ] |
HeliMLM wrote: Sorry, it seems i did not read your post carefully enough did you try to connect a different tail servo just for a test? No worries. I'll will be trying another servo this weekend. |
Author: | nzlsubzero [ Sat 29. Jul 2023 6:17:35 ] |
Hi All I tried a new servo and still the same. I then decided to remove the gyro gain setting for the TX and now I have full travel. Not sure why this is the case, but it now works. I'm setting up the heli for someone else on an OpenTX Taranis transmitter. Thanks for the suggestions. |
Author: | yufasa [ Sat 29. Jul 2023 12:40:02 ] |
Maybe you have changed settings in advanced/revomix or advanced/piro consistency? Another thing to do would be to first back up your settings, just incase, and then do a factory reset followed with a fresh setup? |
