Powering spirit WiFi module https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5717 |
Page 1 of 3 |
Author: | azaz44 [ Thu 15. Jun 2023 20:27:43 ] |
Post subject: | Powering spirit WiFi module |
Quick question - I have Spirit unit powered by BEC. Can I connect Spirit Wifi-Link to it, but have the Wi-Fi Link powered from external 2S lipo? |
Author: | nichtdiemama [ Fri 16. Jun 2023 5:23:30 ] |
Post subject: | Re: Powering spirit WiFi module |
I have the same question. |
Author: | ZeXx86 [ Fri 16. Jun 2023 7:14:17 ] |
Yes, but only if ground wire is shared between battery and BEC. This mean you might need Y cable for powering lead where side that goes to the Spirit unit should be without red wire. |
Author: | nichtdiemama [ Fri 16. Jun 2023 7:43:08 ] |
Isn’t there an gnd connection in the wire between the spirit and the wifi module? |
Author: | ZeXx86 [ Fri 16. Jun 2023 8:00:08 ] |
Yes, it is if you connect powering wire from the Wifi-Link to the Spirit unit. |
Author: | azaz44 [ Fri 16. Jun 2023 8:10:26 ] |
I wonder if we could take the ground from the black lead of the battery, which is easy to access over balancing port. I think it's probably equal to BEC ground, but I better test this before. |
Author: | azaz44 [ Fri 16. Jun 2023 8:15:44 ] |
azaz44 wrote: I wonder if we could take the ground from the black lead of the battery, which is easy to access over balancing port. I think it's probably equal to BEC ground, but I better test this before. I think I'm talking rubbish It seems it's just a matter of providing 2s Lipo ground to Spirit SYS port and things should work. |
Author: | ZeXx86 [ Fri 16. Jun 2023 8:30:34 ] |
Yes, Ground can be connected anywhere with the BEC. |
Author: | Mattes61 [ Fri 16. Jun 2023 8:42:19 ] |
One point should be minded - not all ESC's like additional powersupply as Buffer-Packs or batteries - Regards |
Author: | azaz44 [ Fri 16. Jun 2023 9:02:10 ] |
Mattes61 wrote: One point should be minded - not all ESC's like additional powersupply as Buffer-Packs or batteries - Regards Yes, but we only want to connect ground. Powerline of 2s will not be shared with BEC. |
Page 1 of 3 | All times are UTC + 1 hour |
