Spirit System
[SOLVED] Spirit GTR no signal on THR
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5682
Author:  Fastmover [ Fri 26. May 2023 16:26:46 ]
Post subject:  [SOLVED] Spirit GTR no signal on THR
I want to use my Jeti Mezon Controller and the governor from the Mezon but I don't get any signal on THR.
The Mezon dosen't even inizialize.
what might be my problem ? What configuration should i be beware of ?
Thanks for any help
Best regards
Robert
Author:  ZeXx86 [ Fri 26. May 2023 17:57:08 ]
Post subject:  Re: Spirit GTR no signal on THR
please set Throttle Range to 1000 - 2000us. Then it will work.
Author:  Fastmover [ Sat 27. May 2023 5:40:44 ]
Yes I allready checked that the throttle range is set to 1000 - 2000 but this dosen‘t help ☹️
I also tried to connect a servo instead of the esc and it also shows no reaction !
Any further Ideas ?
Best regard
Robert
Author:  ZeXx86 [ Sat 27. May 2023 7:04:54 ]
Please make sure that Throttle is assigned at Channel 1 and in your radio there is default channel layout - Model Type set to Spirit.
Author:  Fastmover [ Sat 27. May 2023 17:44:16 ]
Checked everything twice and it diden‘t work ! So yesterday evening tokk frustated 3 beer and went to sleep !
This morning i wanted to start all over and gues what „IT WORKS“
I don‘t know what wend wrong, probably I just should have started the Sytem new.
So many thanks anyway for the quick replys .
Best regards
Robert
Author:  ZeXx86 [ Sun 28. May 2023 20:03:55 ]
Post subject:  Re: [SOLVED] Spirit GTR no signal on THR
Sometime beer can resolve an issue :)
http://www.phpbb.com/
