It is currently Sat 23. Nov 2024 0:49:06
PostPosted: Thu 10. Nov 2022 20:54:27
Hello I have two questions and I hope that I will be clear enough.
1/ What do I need to use "Open Flight Viewer in the 3D Player from the Advanced flight Viewer feature ?
I have triggered a lot of logs but I actually don't have any telemetry feature. So I assume that the issue comes from there ? What would I need to be able to replay a flight in 3D ?
The other question about Automatic Rescue.
I'm using a Futaba T14SG with rescue triggered by a switch on bank 0 (everything is working perfectly well).
I would like to enable automatic rescue on bank 1 to make some tests, but when I switch to Bank 1 it does not seem to work.
My way of doing the test :
I take off, fly to 10 meters high and then switch to bank 1 (which has the automatic rescue configured and as I understood should save the altitude). I go 10 meters higher, but when I go below the saved altitude, the rescue does not trigger.
My feeling is that I cannot have automatic rescue working if I have switch rescue configured on bank 0.
Could someone help me please ? Is it possible ? Do I understand well how automatic rescue works ?
Any advice will be welcome given that I'm new to RC helico :).
Edit : To have a better understanding maybe I should add what I would like to have :
Bank 0 => channel 8 to use rescue manually
Bank 1 => auto rescue activated by default, so when I switch to bank 1 to saves the heigth.
But with wy futaba T14SG I don't see how to be able to setup that. And if I use gyro gain to enable rescue mode instead of a dedicated rescue switch, then I will be in bank 1 with gyro with gain = 0.
PS : Special thanks to the team in charge of the development of this gyro. It is really awesome and provide a lot of confidence while flying.
File comment: Here is the config file for Bank 1
Bank 1.4ds [255 Bytes]
Downloaded 41 times
File comment: Here is the config file for Bank 0
Bank 0.4ds [255 Bytes]
Downloaded 36 times
PostPosted: Thu 10. Nov 2022 21:48:44
I reply myself because I found the solution in another post for auto rescue ... I thought I had to use banks to be able to have both rescue modes but on the bench it seems that it work to setup a switch for rescu normal and another switch to auto rescue on the same bank.
Thanks to this post with screenshots : viewtopic.php?f=20&t=4972&start=10
But I still have my question about flight replays if someone already did that :).
PostPosted: Tue 28. Mar 2023 19:39:41
Wondering about 3d Player myself. Have you found a solution?
PostPosted: Fri 26. May 2023 7:13:08
Hey sorry for my late reply.
No I still haven't found any solution ... still looking for information linked to 3D flight viewer.
PostPosted: Fri 26. May 2023 8:37:05
I use only bank 0 in this bank I have altitude limit (it's the same to the rescue automatic) , rescue normal, return to home.
just make sure to activate one function at a time.
you fly arrive at an altitude of 10 metres and active the rescue automatic.
Now you fly, if you go below the quota he activates.
If you go into the ball and you are above 10 meters activate normal recovery.
why normal recovery has priority compared to automatic rescue.
But all on bank 0
Add bank change it's an extra feature that's best avoided
I also used the flight log but I did not understand what do you want to know, from spirit software see logs.
PostPosted: Fri 26. May 2023 11:42:49
Thanks for your explainations.
Through spirit software from the computer, you can see in the menus Diagnostic > Open advanced flight viewer, a box called "3D player" and a grey button called "Open Flight Viewer". For me it is something like replay in 3D your flight, but I am not able to click on it.
Am I the only one ? Should I enable some other feature ? I would especially understand how to use this feature. (I have no telemetry system enabled).
Thanks in advance to the one who will help me :).
Have a good day.
PostPosted: Fri 26. May 2023 14:07:24
in diagnostic you click configure logging to enable in-flight data logging.
decide what you want to record.
altitude
rpm
vibration level
bec voltage
ecc
PS
the data of the esc They are different.
and after set 25hz or 10hz (every how many milliseconds you log)
and now you fly.
every time you turn on the controller and start flying a log file is created
after you shut down the helicopter to save the file
Now if connect the spirit and you click select log select the recorded log
normally you see it in the graph in the horizontal line see the seconds go by
in the vertical bar see recorded values.
when you uploaded the log maybe instead of seeing them in the graph you will be able to see them in 3d.
this 3d visualization I've never used it but I think it's an alternative to the 2d graph.
I've only used the logs once why the gt has the logs and I set up a helicopter of my friend and had the gt.
I have the spirit rs and does not have the logs, I use radio logs.
If one day logs will be added to spirit rs certainly i will use them.
try uploading the logs and see if it works the 3d player
PostPosted: Fri 26. May 2023 18:21:44
at the moment 3D player is not available. But it will be ready in around 2 months.
PostPosted: Fri 26. May 2023 19:28:09
Oh god thanks a lot. I was beginning to think that I am crazy :).
I'm in a hurry to check out this feature. I hope it will be available even without telemetry installed.
altitude
rpm
vibration level
bec voltage
ecc
PS
and now you fly.
Thanks for your information. I actually noticed all of that logs. I was mainly interested in the 3D player feature that's all.
Thanks again mate !
Users browsing this forum: Bing [Bot] and 64 guests
