It is currently Sun 06. Apr 2025 6:35:42
PostPosted: Fri 12. May 2023 8:00:15
I have been using a 4650T in a small Oxy3 Qube for a few years without any issues. I have moved this setup to a Gaui X3, but am wondering if I should add a second SRXL2 "sat" to the setup, either another 4650T or the 4651T.
In this link: http://manual.spirit-system.com/index.p ... t_Settings in section 1.2.2 it seems to indicate that I can add a second SRXL2 unit using your special cable.
When I went to order it from your Estore, it seems to indicate this will not work with my old original "red" Spirit. https://store.spirit-system.com/en/acce ... cable.html
Will it work with my original red Spirit?
If not, what is the next best option to add redundancy? Will my 4650T plug into a AR6610T using one of those various plugs in see in the online picture.
Thanks.
PostPosted: Fri 12. May 2023 8:27:49
for Gaui X3 I believe one SRXL2 satellite is more than enough.
Using full size receiver such as AR6610T could be safer but still I think it is not needed unless you are flying to a far distances.
PostPosted: Fri 12. May 2023 9:01:27
I am flying an Align Dominator 450L with just one 4651T without any problems, for years -
I placed this satellite below near the landing gear, the antennas are 45° apart (antennas form a 90° angle).
PostPosted: Fri 12. May 2023 15:04:48
Thanks to both of you. I will stay with my single 4650T.
