Spirit GTR: AUX for switching channel https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5621 |
Page 1 of 1 |
Author: | fraje [ Sat 08. Apr 2023 23:07:45 ] |
Post subject: | Spirit GTR: AUX for switching channel |
Hi guys, How can I use the AUX port as a switching channel as it´s described for a landing gear or lights? I have a 1st cap buffer and would like to switch it on/off thru the AUX port. I tried a channel 9 assignment in the functions panel (output to AUX). The switch is working but has no affect on the connected cap buffer. FW: 3.4.3 TX: Jeti DS-16 Thanks in advance. |
Author: | Mattes61 [ Sun 09. Apr 2023 11:27:26 ] |
Post subject: | Re: Spirit GTR: AUX for switching channel |
Hi, I have also an 1st-Buffer with three cables +, - and Signal on it - my first consideration was to do that in the same way as you - but I haven't tested it myself yet, it will take a while, but I suspect that the firmware of the 1st buffer may not have implemented it yet, I seem to remember that there was a "*" after the specification and at the bottom, it will be possible in a later version (firmware) - but as soon as I get around to it, I'll still check whether it's already working and let you know - Regards Short addendum, try it with aux2...: Attachment:
Author: | HeliMLM [ Sun 09. Apr 2023 16:19:03 ] |
... it is working as you explained - at least on mine. the buffer can only be switched off when the buffer is supplying the power (main battery disconnected). as long as main battery is connected the buffer will ignore on/off switching signal from Tx (which makes perfect sense to me). |
Author: | fraje [ Fri 16. Jun 2023 19:23:55 ] |
Even with GTR FW, V3.5 it´s still not working with 'F:Output to Aux' and a connected CAP at the AUX port. But it´s working with 'F:Output to CH0' and connection to CH0 port (default= 2. elevator servo). I tried it with 1st-buffer and IISI-RC cap. |
