It is currently Fri 22. Nov 2024 23:06:54
[ 5 posts ] |
fclement
Posted: Wed 08. Mar 2023 17:41:04 |
I can't make the telemetry from my ESC working. My config :
- microSpirit - Spektrum SPM 4650 receiver ( SRXL2 ) - DX8 G2 - Castle Creation Talon 15 A
I think telemetry from the microspirit is working because I can see the " Status ESC " screen : Gaz and Vibration level are OK. I have enabled " Link live " on the ESC and also " Castle Creations Phoenix & Talon " on the spirit. Throttle is channel 1 and the ESC cable is connected to AUX. I can access the spirit config screen on my radio. But as you can see in the picture attached, all ESC values are 0.
Any idea ? Do I need to change something on my radio ?
Attachments: |
10x
Posted: Wed 08. Mar 2023 18:40:49 |
fclement
Posted: Thu 09. Mar 2023 19:28:09 |
Thanks for your reply !
Well, I though it was just a cable but as I'm seeing it, I'm wrong : this cable has electronic....isn't it ?
I will order it today.
Regards,
10x
Posted: Thu 09. Mar 2023 21:20:16 |
"For Experts: Alternatively you can modify your current Throttle cable by adding 10kOhm resistor between white (signal) and red (+) wires. In this case the Telemetry cable is not required." From the manual...
fclement
Posted: Wed 15. Mar 2023 21:56:14 |
Yes, thanks !
But I want to be sure that telemetry is working with the spirit cable because the ESC cable is short and it is not easy to solder the resistor. I will try with a PCB resistor because I need to save weight, the weight of my tiny heli is ~ 100 g.
[ 5 posts ] |
Users browsing this forum: No registered users and 37 guests |
