It is currently Fri 22. Nov 2024 23:14:08
 Post subject: 5 blade phasing
PostPosted: Mon 06. Mar 2023 11:02:22
A question on phasing a 5 blade head. I notice there are degrees of up to 90 and also -90. I know I need to move the swash a full 90 degrees but how do I know if I need +90 or -90?
Thanks, T
 Post subject: Re: 5 blade phasing
PostPosted: Tue 07. Mar 2023 15:13:17
When you are moving elevator stick forward and backward, you should see correct direction of the swashplate movement.
At the same time parallel blade with the boom should not move at all. But the rest of the blades should move.
When moving with aileron stick then parallel blade should move.
PostPosted: Tue 07. Mar 2023 22:23:13
Thank you for the reply. I think I have that right. Now when checking the gyro corrections, when moving the elevator stick should I see the blade grips move the opposite way? In other words, stick forward, grips move forward. Tilt helicopter forward, grips move backwards. It's a bit difficult to watch the swash plate because it does not move in a normal way. Hope this makes sense.
Tony
Users browsing this forum: No registered users and 50 guests
