It is currently Sat 23. Nov 2024 4:36:21
PostPosted: Thu 18. Nov 2021 1:16:24
Had an incident yesterday on my nitro model where I landed to adjust the tuning and spooled up a short while later and the governor decided I was trying to perform an 'Autorotation Bailout' and did a fast spool up on the ground, tail kicked out, model tipped over and smashed blades.
Please explain how to DISABLE 'Autorotation Bailout rate' please!
Edit: did some searches, appears throttle needs to be below 12% to disable. Currently my motor idles at 13%, I have played around with the servo end points to ensure idle at <12% to make sure ARB is disabled whenever I hit throttle hold.
I do think that there should be an option to completely DISABLE this feature, I doubt that could cause any confusion. Please consider this.
PostPosted: Thu 18. Nov 2021 9:08:08
You are right, when throttle is that high for idling, it will behave exactly in this way.
We will implement it and add new options for setting up bailout.
PostPosted: Tue 31. Jan 2023 21:57:00
Is there a way to turn off the bailout feature? Or is there another way to work around it. FBL is the Spirit GTR.
Users browsing this forum: Bing [Bot] and 58 guests
