It is currently Sat 23. Nov 2024 4:17:03
[ 3 posts ] |
treys1
Posted: Mon 30. Jan 2023 0:56:51 |
Hello, playing around with a Spirt GT after ~3 off from Helis (but several years with Spirit 1 & Pros), and I just want to confirm the following config is OK.
F. Stabilization (Normal) - 7. Channel F. Rescue (Automatic) - 8. Channel F. Rescue (Normal) - 9. Channel
Only reason I want all 3 is that I am still getting comfortable after a few years off and want to have the Stabilization available JUST if I have orientation issues while flying and need help getting my bearings to bring it back.
Thought process is take off, enable Rescue (Automatic) for the hard deck and use Rescue (Normal) if something happens above the deck, WITH Stabilization there just in case its needed, but to rarely use.
To clarify, I have already set up and tested:
And it worked just fine, was hoping to add the Rescue (Normal) in there as well.
Posted: Mon 30. Jan 2023 8:53:01 |
yes, your settings looks good. It can work in that way.
treys1
Posted: Mon 30. Jan 2023 15:29:58 |
[ 3 posts ] |
Users browsing this forum: No registered users and 37 guests |
