HW Platinum V5 - Incorrect Telemetry Values https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5514 |
Page 1 of 1 |
Author: | pb3d [ Mon 26. Dec 2022 14:59:36 ] |
Post subject: | HW Platinum V5 - Incorrect Telemetry Values |
Hi Spirit Pilots, I am using HW Platinum Pro150a V5 and Scorpion HKIV-4025/1100kv, with Spirit GT, Rx AR6610T and TX DX8 G2 on SAB Raw 700 Piuma. I have updated the ESC firmware to the latest version but the telemetry works only partially. The RPM, battery voltage and temperature data are shown correctly on the telemetry screen. However, the current and the battery used capacity are about 10 times too low - showing 10-15amps and 240-300mah for 5500mah lipos. I have contacted HW support, but they could not answer my question. Please share your experience. Thanks PB |
Author: | Mattes61 [ Mon 26. Dec 2022 17:15:51 ] |
Post subject: | Re: HW Platinum V5 - Incorrect Telemetry Values |
Hello, maybe this link helps for info - What firmware are you flying ? I am not shure if the problem was already solved - Maybe Tomas can say something about that - https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5443 Regards |
Author: | pb3d [ Tue 27. Dec 2022 9:36:11 ] |
Mattes61 wrote: Hello, maybe this link helps for info - What firmware are you flying ? I am not shure if the problem was already solved - Maybe Tomas can say something about that - https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5443 Regards Thanks much Mattes61 - I read this post, but it seems open-ended - no solution. |
Author: | ZeXx86 [ Tue 27. Dec 2022 17:59:14 ] |
Hello, please wait for the new firmware release. The fix is there. Thank you for your patience. |
