that sounds for me that your gas paths were never taught - If you connect the battery with throttle in maximum position the esc should beep and then you should set the throttle back to minimum but in the normal way your throttle has to be in minimum - so far I haven't had any problems with hobbywing esc's regarding telemetry and correct initialization -
The fact is that the Spirit initializes correctly even without a receiver - but I still think that there was something wrong in the previous configuration -
Dudemeister wrote:
As long as I went through the initialization process I mentioned before (throttle @ max) while powering it up, the it would work fine, and I flew 3 battery packs without any issues. But I still wanted telemetry, so to that end, I replaced the DSMX with an FrSky Archer RS, and the strange swash behavior is gone. I also replaced the Hobbywing Platinum ESC with a Castle Edge Lite 50.
https://manual.spirit-system.com/index.php?title=Problems_and_SolutionsAttachment:
Matthias
