It is currently Sat 23. Nov 2024 3:33:09
[ 8 posts ] |
Airjunkie
Posted: Wed 07. Dec 2022 19:26:00 |
I know it sounds weird, but is it possible to use the Spirit RS just as a Jeti reciever with another fbl which is connected to it? If yes, how should the other Fbl connected/wirred with the Spirit? Regards Stephan
Airjunkie
Posted: Mon 12. Dec 2022 14:45:12 |
Posted: Mon 12. Dec 2022 15:04:06 |
You can connect anything to Spirit RS/GTR to E1 configured to EX Port. However I guess it is better to use properly configured Spirit unit. Or is there a reason why it can't be used on the model?
Airjunkie
Posted: Thu 15. Dec 2022 17:22:13 |
Indeed it has to do with my tail issue in my Specter over which i wrote in another thread here. And i want to know which possibilitiest exists to use another fbl in combination with the spirit reciever.
gerry
Posted: Fri 16. Dec 2022 6:39:54 |
Joined: Fri 26. Aug 2016 6:51:10 Posts: 227 Location: Austria
Hello Stephan. Your tail problem has absolutely nothing to do with the Spirit FBL, I've been flying this system for a long time and every tail problem has been solved. Before you use the Spirit as a receiver and attach another FBL to it, I would optimize the ease of movement of the tail linkage and the settings. Greetings Gernot
_________________ Greetings from Gernot
Airjunkie
Posted: Fri 16. Dec 2022 15:08:20 |
Hi Gernot thanks for your comment. I don't want discuss this here. We can talk about it in the "tail issue" thread. It was importent for me if there is a possibilitie to use the Spirit as a simple reciever!
Regards Stephan
Posted: Fri 16. Dec 2022 15:13:28 |
I will try to get settings file from our team pilot that is flying Specter. He is attending flight events with this helicopter as well and there is no tail issue.
Airjunkie
Posted: Fri 16. Dec 2022 19:36:25 |
Thank you, but remember that i have a Specter V2.
[ 8 posts ] |
Users browsing this forum: No registered users and 52 guests |
