Using the Spirit RS just as a Jeti reciever https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5502 |
Page 1 of 1 |
Author: | Airjunkie [ Wed 07. Dec 2022 19:26:00 ] |
Post subject: | Using the Spirit RS just as a Jeti reciever |
I know it sounds weird, but is it possible to use the Spirit RS just as a Jeti reciever with another fbl which is connected to it? If yes, how should the other Fbl connected/wirred with the Spirit? Regards Stephan |
Author: | Airjunkie [ Mon 12. Dec 2022 14:45:12 ] |
Post subject: | Re: Using the Spirit RS just as a Jeti reciever |
No idea? |
Author: | ZeXx86 [ Mon 12. Dec 2022 15:04:06 ] |
You can connect anything to Spirit RS/GTR to E1 configured to EX Port. However I guess it is better to use properly configured Spirit unit. Or is there a reason why it can't be used on the model? |
Author: | Airjunkie [ Thu 15. Dec 2022 17:22:13 ] |
Indeed it has to do with my tail issue in my Specter over which i wrote in another thread here. And i want to know which possibilitiest exists to use another fbl in combination with the spirit reciever. |
Author: | gerry [ Fri 16. Dec 2022 6:39:54 ] |
Hello Stephan. Your tail problem has absolutely nothing to do with the Spirit FBL, I've been flying this system for a long time and every tail problem has been solved. Before you use the Spirit as a receiver and attach another FBL to it, I would optimize the ease of movement of the tail linkage and the settings. Greetings Gernot |
Author: | Airjunkie [ Fri 16. Dec 2022 15:08:20 ] |
Hi Gernot thanks for your comment. I don't want discuss this here. We can talk about it in the "tail issue" thread. It was importent for me if there is a possibilitie to use the Spirit as a simple reciever! Regards Stephan |
Author: | ZeXx86 [ Fri 16. Dec 2022 15:13:28 ] |
I will try to get settings file from our team pilot that is flying Specter. He is attending flight events with this helicopter as well and there is no tail issue. |
Author: | Airjunkie [ Fri 16. Dec 2022 19:36:25 ] |
Thank you, but remember that i have a Specter V2. |
