It is currently Mon 25. Nov 2024 11:12:52
 Post subject: Throttle channel
PostPosted: Sat 21. Mar 2015 23:55:16
Hi All
I am trying to setup my Trex 600N on the Spirit System controller.
I am part the way there but i am not sure about a couple of things.
When i have set up the system using a spektrum receiver and satellite
the throttle servo plugged into the throttle port on the receiver works but the throttle channel were you adjust the 100 percent travel and centre point doesn't move. is it suppose to?.
Also the pitch travel is never equal when i set the pitch range. I have to do the servos individually even though the servo geometrics are set to 90 degrees on the servo horns
Paul
 Post subject: Re: Throttle channel
PostPosted: Sun 22. Mar 2015 12:53:29
Hi, I am confused.
Are you using the "Spektrum satellite setup" (with the Sat connected to Spirit)?
Or are you using a Spektrum receiver "standard PWM receiver setup" (with the Sat connected to the receiver)?
In the latter case you can't see throttle in the Spirit diagnose.
PostPosted: Sun 22. Mar 2015 13:00:35
Hi
It is setup with the receiver connected to the satellite and then the spirit connected to the receiver
so your second option.
Users browsing this forum: Bing [Bot] and 10 guests
