Servo frequency and pulse settings for motor driven tail https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5490 |
Page 1 of 1 |
Author: | Colin [ Mon 28. Nov 2022 16:55:53 ] |
Post subject: | Servo frequency and pulse settings for motor driven tail |
I’ve been playing around with a motor driven tail on a Trex 500 with a spirit pro, can anyone tell me the frequency and pulse settings in the wizard’s servo set up page?? |
Author: | ZeXx86 [ Mon 28. Nov 2022 20:47:16 ] |
Post subject: | Re: Servo frequency and pulse settings for motor driven tail |
Please specify what is ESC that you are using. This is the most important thing for motor drives. The most ESCs are not sufficient for tails, because they can`t handle more than 120Hz or will ignore higher frequencies. |
Author: | Colin [ Mon 28. Nov 2022 22:40:12 ] |
I will be using a HobbyWing 60A platinum v4 ESC in airplane mode with a BrotherHobby Avenger V2 2507 1750 Kv motor , I got the motor detail from https://grabcad.com/library/500-size-ga ... ron-duct-1 and sized the esc according to motor Kv and using a 6 cell lipo. |
Author: | ZeXx86 [ Wed 30. Nov 2022 9:06:23 ] |
You can try to use 120 - 200Hz there. Pulse is 1520us. Please dont forget to set Rudder Control Type parameter to Motor in the Advanced - Expert settings. |
Author: | jasc [ Wed 30. Nov 2022 12:43:47 ] |
If you are brave you could also look at this project https://github.com/rotorflight/rotorflight |
