Spirit System
Hobbywing 150 Platinum V5 ESC
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5478
Author:  Harleyflyer1000 [ Thu 17. Nov 2022 21:32:53 ]
Post subject:  Hobbywing 150 Platinum V5 ESC
I am thinking about getting a Hobbywing 150 Platinum V5 esc and Spirit GT FBL for an upcoming helicopter project. Does this esc have full telemetry functionality with Spirit FBL’s?
Thanks!
Author:  kc8cyf [ Thu 17. Nov 2022 23:03:54 ]
Post subject:  Re: Hobbywing 150 Platinum V5 ESC
I don’t think the HW150 v5 “FunFly” series have any telemetry capability at all. It may not even have an RPM output either. That ESC was meant for airplane use… however, a good FBL governor can run it (you may need the phase sensor to get RPM). I would recommend looking on HeliFreak for posts from AtomicSkull regarding the Hobbywing v5 FunFly units. Their main attraction is the low cost, but there’s a bit of more work to get them working well in a helicopter application.
The programming device is a push button LED card… it does not use the PC adapter/programming box. I don’t know if firmware can even be changed, unless done at the factory.
Author:  Harleyflyer1000 [ Fri 18. Nov 2022 3:21:26 ]
I was referring to the Hobbywing 150 Platinum Pro v5, not the Fun Fly series.
Author:  kc8cyf [ Fri 18. Nov 2022 5:55:27 ]
Gotcha. That’s a new one for me. Looks promising and concerning at the same time… VBC integration/telemetry as a native setup; we know the V4 units with VBC firmware doesn’t work with Spirit, so it’s possible that this v5 will not work as well.
If I had a 550 size heli, I’d definitely try it.
We’ll look out for someone who gives it a go.
Looks like MSH had a recent update to allow telemetry with the v5 series. Maybe Jeti and Spirit will get an update soon.
New Hobbywing 150A V5
https://r.tapatalk.com/shareLink/topic? ... source=app
Author:  Danoo [ Fri 18. Nov 2022 9:20:25 ]
Hobbywing 150A v5 works with Spirit GT!
There is an issue with used capacity, which is already recognized and will be fixed with next update.
https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5443
Author:  Harleyflyer1000 [ Fri 18. Nov 2022 21:51:48 ]
Great, thanks for the feedback!
Author:  BRITinUS [ Sat 19. Nov 2022 0:54:33 ]
Thanks!
I am using a Hobbywing 150 Platinum V5 esc and Spirit GT FBL on a Goblin 580 Raw build. Full telemetry works perfectly with a Graupner Tx and Rx.
Author:  Harleyflyer1000 [ Sat 19. Nov 2022 17:57:06 ]
That is great news! The helicopter project that I’m thinking about is the Goblin 580 Raw. Perfect and thank you!
Author:  BRITinUS [ Sun 20. Nov 2022 1:34:02 ]
Great choice -this is my first RC helicopter build, I've only flown fixed wing aircraft up until now. A couple of other members at the club where I fly have Goblin 580s, one with a Spirit flybarless unit . I'm just in the process of mounting the Spirit GT and Rx in my build at the moment. I'll post some photos when done for anyone who's interested.
Author:  curmudgeon [ Sun 20. Nov 2022 4:04:16 ]
HobbyWing Platinum V4 and V5 ESC series are considered good value ESCs, but they are not known for telemetry accuracy or repeatability.
http://www.phpbb.com/
