Rescue and stabilization Function wird one Channel? https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5470 |
Page 1 of 1 |
Author: | pinkisoft [ Sun 13. Nov 2022 15:14:47 ] |
Post subject: | Rescue and stabilization Function wird one Channel? |
Hello, I need a recommendation for parameterizing the rescue function and stabilizing with as few channels as possible. I need: Mode 1: normal flight mode Mode 2: Stabilization Mode 3: Rescue function Can you set the fact that you only need one channel for it? Ideally via a 3-way switch with one channel. Or what is the best way to set the recommendation? Thanks for the info. |
Author: | pinkisoft [ Tue 15. Nov 2022 22:17:27 ] |
Post subject: | Re: Rescue and stabilization Function with one Channel? |
No Idea? Does it work with one Channel? I Hope for help |
Author: | Frigetrus [ Tue 15. Nov 2022 23:52:32 ] |
Post subject: | Re: Rescue and stabilization Function wird one Channel? |
Hi! The easiest way to use different stabi functions is to use bank switching. You can set up 3 banks, after it you can switch between them with a 3 way switch. |
Author: | ZeXx86 [ Thu 24. Nov 2022 10:34:32 ] |
If you need to use only one channel for all these functions then you really need Bank Switching. Then Unassign Gyro Gain channel in the General - Channel and set it in the Sensor Tab to a minus value. For example -50% if you are using 50% Gyro Gain normally. Then for each bank set different Stabi/Function and it will work well in this way. |
