It is currently Fri 22. Nov 2024 13:06:58
PostPosted: Sun 13. Nov 2022 15:14:47
Hello, I need a recommendation for parameterizing the rescue function and stabilizing with as few channels as possible.
I need:
Mode 1: normal flight mode
Mode 2: Stabilization
Mode 3: Rescue function
Can you set the fact that you only need one channel for it? Ideally via a 3-way switch with one channel. Or what is the best way to set the recommendation?
Thanks for the info.
PostPosted: Tue 15. Nov 2022 22:17:27
No Idea?
Does it work with one Channel?
I Hope for help
PostPosted: Tue 15. Nov 2022 23:52:32
Hi!
The easiest way to use different stabi functions is to use bank switching. You can set up 3 banks, after it you can switch between them with a 3 way switch.
Jeti DS12, Align T-Rex 470L with Spirit GTR, Soxos Strike 7 with Spirit GTR
PostPosted: Thu 24. Nov 2022 10:34:32
If you need to use only one channel for all these functions then you really need Bank Switching.
Then Unassign Gyro Gain channel in the General - Channel and set it in the Sensor Tab to a minus value. For example -50% if you are using 50% Gyro Gain normally.
Then for each bank set different Stabi/Function and it will work well in this way.
Users browsing this forum: Bing [Bot] and 61 guests
